The Metabo HSS-Co Drill Bit Set is designed for drilling into steel, stainless steel, cast steel, non-ferrous metals, plastics and special alloys with tensile strengths of up to 1100 N/mm². Manufactured from a high-performance cobalt alloy, the drill bits feature a precision-ground cylindrical shank and a 135° split point for accurate positioning and efficient drilling. The bronze-coloured finish enhances durability and wear resistance.
Supplied in a robust metal storage tin, this versatile 19-piece set is ideal for a wide range of professional and DIY applications. Set contains one of each size: 1, 1.5, 2, 2.5, 3, 3.5, 4, 4.5, 5, 5.5, 6, 6.5, 7, 7.5, 8, 8.5, 9, 9.5 & 10mm.
Web Attribute Set Drill Bit Sets
EAN Barcode 4007430175861
