Replacement drift pin for easy pilot drill tip removal from the UJK Pocket Hole Drill.
Unlike standard pocket hole drill, which often have tips that break, with these, you can quickly change the tip rather than buying a whole new drill.
Intended Use The process of joining wood at an angle, without visible fasteners.
Web Attribute Set Wood Boring Bits
EAN Barcode 5052511136742
