The Axminster Professional AP20BD Bench Drill 230V is a robust and versatile machine designed to meet the needs of any workshop. This drill features a precision spindle running in genuine NSK ball bearings, ensuring accurate drilling and low vibration. The multi-vee type belts provide maximum grip and low vibration, contributing to the smooth operation of the machine. The spindle assembly is a good fit into the headstock, enhancing the overall stability and accuracy of the drill.
Safety is a top priority with the AP20BD. It comes equipped with an electrically interlocked chuck guard that prevents the machine from being accidentally turned on, and an integrated belt cover safety switch that stops the drill from running with the cover open. Additionally, the adjustable LED work lamp provides excellent visibility of the workpiece, ensuring precise and safe drilling operations.
The ergonomic design of the AP20BD includes a one-piece cast iron handle with soft rubber grips for comfortable and smooth operation. The quality 1-16mm keyless chuck allows for quick and easy changing of drill bits, while the rack and pinion table adjustment ensures quick and easy table adjustments. Plus, with the improved depth stop design, you can make easy adjustments for precise drilling depths. Its compact design makes it an ideal addition to any workshop, offering both functionality and convenience.
Please note, if you require an EU plug, please ensure you purchase 113504
Overall L x W x H 670 mm x 360 mm x 1,020 mm
Power 750 W
Rating Frequent Use
Table Size 290 mm x 290 mm
Table Tilt 45 - 0 - 45
Chuck Capacity 1 mm to 16 mm
Chuck Type keyless
Throat Depth 178 mm
Plug Fitted UK 3 pin plug
Web Attribute Set Drilling Machines
EAN Barcode 5052511136346
