A handy addition to your 63mm extraction system. This Floor and Bench Gulper Attachment is made up of nine parts. The parts can be put together in various configurations to help make your workshop a cleaner place.
It comes with two adaptors allowing you to connect the hand piece to 63mm or 38mm hose. With the long floor tube and floor nozzle fitted you can make short work of getting rid of dust and shavings around the workshop. Replacing the floor tube with one of the two bench nozzles lets you clean up not only your bench but also dust and shavings on or around any machines. The kit includes two hose clips and two wall clips.
EAN Barcode 5052511125647
