This Axminster Magnetic Hose Coupler Kit provides a practical way to connect a single dust extraction hose to two machines. Designed to create quick, reliable magnetic connections, it allows the hose to be transferred between extraction points in seconds, reducing time spent changing hoses and helping keep dust extraction in use throughout the workshop. The self-aligning magnetic connection provides a secure fit while releasing easily when it's time to move to the next machine.
The kit contains two 100mm female steel-ring couplers, one 100mm male magnetic coupler, two 100mm rubber cuffs and one 100mm retaining clip. The magnetic coupler is fitted to the dust extraction hose using the supplied clip, while the female couplers are mounted to individual machines using the rubber cuffs. Manufactured from durable workshop-grade materials, the components are designed for reliable everyday use and can be installed quickly into a wide range of 100mm dust extraction systems.
Designed by Axminster for practical workshop use, this kit makes it easy to expand a magnetic dust extraction system across multiple machines. Suitable for professional workshops and home woodworkers alike, it offers a straightforward solution for improving the speed, convenience and efficiency of dust extraction.
EAN Barcode 5052511147021
