The Axminster Professional AP750DE Dust Extractor is a reliable and efficient dust extractor designed for professional use. Built to deliver consistent performance, it combines effective dust collection with features that make day to day operation in a small workshop, convenient and easy.
The machine is powered by a 750W motor, and features a balanced steel impeller ensuring long service life and dependable airflow of 795 m3/hr @ 100mm. The cartridge filter provides fine filtration down to 0.99 > 1 micron and increases the potential use of the machine to include sanders, as well as saws, planers etc. The hand crank filter paddles allow easy and quick filter changing.
With a bag capacity of 57L, the extractor is fitted with bag clips and quick fit straps for simple bag changes. Larger wheels improve portability, making it easy to move around the workshop as required.
A particular highlight is the time delay switch with remote control. This allows you to leave the extractor running after finishing a task, helping to clear any dust remanence. The remote control makes it possible to switch the unit on and off anywhere in the workshop - even if the extractor is located outside of the working area.
Airflow 795 m³/hr @ 100 mm
Filter Performance 99% 1 micron
Overall L x W x H 826 x 515 x 1470 mm
Power 750 W
Rating Frequent Use
Sound Power Level LwA [Uncertainty K] 77 dB(A)
Plug Fitted UK 3 pin plug
Model AP750DE
Bag Capacity 57 litre
Hose Diameter 100 mm
Nett Weight 36.5 kg
Static Pressure 1,080 Pa @ 100 mm
Voltage 230 V
EAN Barcode 5052511142408
