The Einhell TP-PS 18/165 Li BL PROFESSIONAL is a versatile plunge cut saw designed for precision and performance in any workshop. Ideal for cutting wood, panels, and plastics, its plunge function allows you to start cuts directly from the surface.
Powered by an advanced Einhell Brushless Motor, it delivers greater power, extended runtime, and reduced maintenance compared to conventional carbon brush motors. Plus, register online to enjoy a 10-year motor warranty. Safety features include soft start, motor brake, and restart protection for secure operation.
The saw features a lightweight, compact design with a premium aluminium table for accurate, straight cuts when paired with the parallel stop. A viewing window and cutting line indicator ensure precise alignment, while a spindle lock makes blade changes quick and easy.
For comfort, the saw includes an ergonomic main and front handle with soft-grip surfaces for fatigue-free use. Both cutting depth and tilt angle are easily adjustable without tools. The high-quality carbide blade (Ø165 mm) cuts up to 56 mm at 90° (without guide rail) and delivers clean, edge-close results. A swiveling dust extraction port keeps your workspace tidy, and the saw is fully compatible with the Einhell guide rail system.
Part of the Power X-Change family, this tool uses lithium-ion batteries with advanced battery management for long-lasting performance.
Specifications:
No Load Speed: 5,000/min.
Max. Cutting Depth @90º 56mm, @45° 42mm
Blade: 165mm, 20mm Bore
Bevel Capacity: 57°
Suction Connection Diameter: 36mm
Weight: 4.23kg
