The KNIPEX 98 13 Series Screwdriver is designed for safety and efficiency, making it ideal for all electrical applications around the home or workplace. This screwdriver features an insulated chrome vanadium molybdenum steel blade, ensuring durability and long-lasting performance. The ergonomic, dual-component handle is designed to reduce fatigue and provide optimum transmission of force, making it comfortable to use for extended periods.
The screwdriver is VDE tested up to 10,000V and is safe for work up to 1,000V, conforming to DIN EN / IEC 60900 standards. The handle design not only provides greater torque action but also prevents the tool from rolling off worktops and benches, adding to its practicality and safety.
For: Hexagon Socket Screws 3.0mm
Overall Blade Length: 75mm
Length of Non-Insulated Blade: 15mm
Handle Length: 107mm
Overall Length: 182mm
Web Attribute Set Electricians Screwdrivers
EAN Barcode 4003773026341
