KNIPEX VDE Screwdrivers are designed for safety and efficiency, making them an essential tool for any professional. Manufactured from chrome vanadium molybdenum steel, these screwdrivers feature an ergonomically optimized dual-component handle that reduces fatigue and ensures optimum transmission of force. The handle design also prevents rolling, adding to the convenience and safety of use.
These VDE screwdrivers are tested up to 10,000V and are safe for work up to 1,000V, conforming to DIN EN/IEC 60900 standards. This 6-piece set includes both Phillips and slotted screwdrivers, covering a range of common sizes.
Includes:
2 x Phillips Screwdrivers: PH1 x 187mm, PH2 x 212mm.
4 x Slotted Screwdrivers: 3.0 x 202mm, 4.0 x 202mm, 5.5 x 232mm, 6.5 x 262mm.
Web Attribute Set Electricians Screwdrivers
EAN Barcode 4003773075523
