IRWIN®; Record®; Mechanic's Vice is rigid and robust. The body and sliding jaw are cast from close grained grey iron which is machined on all friction surfaces for a smooth, reliable action. Fitted with hardened steel jaws for extended life, they can be replaced when worn. The main steel screw has a two-start rolled acme thread for faster and smoother operation.Ithas a fused steel handle that will bend before the vice can be overstressed. A safety stop prevents the slide from being separated from the body. The most popular and widely used general purpose vice for light to medium-duty applications.
Web Attribute Set Mechanics Vices
