Axminster Woodturning
Axminster Woodturning Woodscrew Chuck 38mm - 1" x 8tpi
SKU: 910462
€21,00
  • Stainless steel screw 4mm x 19mm
  • Thread form developed for maximum grip
  • Faces have slightly raised rim to ensure firm location of timber
  • 1 x 8tpi thread
The 38mm (1.1/2) diameter wood screw chuck is a great choice for wooden fruit, drawer knobs, finials and other smaller projects of this type. The central screw is stainless steel with a deep sharp thread for a positive and secure hold. It only requires you to drill a single shallow hole in the blank. The screw fitted as standard to the chuck has a core diameter of approximately 4mm and a 19mm tapered thread.
Made in Britain Yes
Thread Size 1 x 8 tpi
Intended Use Quick and convenient method for mounting a turning blank on your lathe.
Web Attribute Set Wood Screw Chucks
EAN Barcode 5052511044726
