The Festool OSC 18 LI E-Basic VECTURO Multi-Tool is a body only machine. At its heart is a brushless EC-TEC motor, which generates plenty of power at the same time drawing relatively little energy from the battery. As a result, you get far more work out of a fully charged battery and extended runtimes.
The VECTURO features variable electronic speed control ensuring fast cuts in a wide variety of materials. The vibration isolation between the motor and slimline housing plus an ergonomic rubber comfort grip offers both comfort and control. The Festool OSC 18 LI 3.1 E-Set VECTURO gives you cordless freedom, greater precision and unbeatable performance. The StarLock Max blade changing system is quick and easy, without the need for tools: simply clip-in, lock and go. Supplied in a SYSTAINER SYS 2 T-LOC carry case, along with a USB 78/32/Bi/OSC universal saw blade.
This is a body only machine without battery or charger. Please note, this does not come with an interface for a depth stop.
Battery Voltage 18 V
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 94 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 83 dB(A) [3.0 dB]
Manufacturer Part Number 574848
Web Attribute Set Cordless Oscillating Tools
EAN Barcode 4014549315842
