The DOMINO FV/16 connector set contains the three elements you need to make several butt joints. It comprises 32 SV-QA D14 cross anchors, 16 SV-DB D14 double-headed bolts and SV-V D14 wideners for 32 cross anchors.
The DOMINO connector revolution makes fast, accurate and powerful connections with the option of quick and easy disassembly and reassembly. The connector system for the DOMINO XL DF 700 joining machine is suitable for material thicknesses of 30mm or more.
Using the DOMINO XL DF 700 to produce the joint is an extremely quick process using only the machine’s stops or simple pencil markings. It requires no other accessories or templates. The finished joint is extremely stable.
