Festool
Festool ES-ETS 125 REQ-Plus Sander with Positioning Aid 230V
SKU: 107466
£464.98
£387.48 Excl. VAT
  • Compact eccentric sander with unique edge sanding attachment
  • Sand perfect edges at any angle between 43 and 92
  • Saves hours of work and results in superior finish
The Festool ES-ETS 125 REQ-Plus compact eccentric sander is well balanced and easily manoeuvrable. The sander has a variable speed selector and 250W of power. The 2mm orbit and eccentric action leave an excellent surface finish in a short space of time. The addition of the unique positioning attachment turns the ES-ETS 125 REQ-Plus into a dedicated edge sander. The attachment provides you with a level of control unachievable using any other method. Say goodbye to laborious hours spent hand sanding edges. Using this combination, you can effortlessly sand small or large workpieces, narrow or wide edges, from 5 to 60mm, angled edges from 43 to 92, external curves and you can sand into an internal corner.
A large surface support ensures complete stability. There is a choice of sanding modes; Hard, the edge is sanded at the pre-set angle. In soft mode the edge sander adapts precisely to the surface to be sanded, for a gentler action meaning neither paint nor filler is sanded through.
The ES-ETS 125 REQ-Plus comes with the AH-ES-ETS/ETSC positioning aid, a StickFix sanding pad (soft-HT), long-life chip collection bag and 4m plug it-power cable in a Systainer SYS3 M 337.
Dust Collection Dust Bag Supplied
Dust Extraction 27 mm Outlet
No Load Speed 6,000 - 12,000 rpm
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 84 dB(A) [3.0 dB]
Corded or Cordless Corded
Cable Length 4 m
Sound Pressure Level LpA [Uncertainty K] 73 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] 3.5 m/s² [2.0 m/s²]
Motor Power 250 W
Plug Fitted UK 3 pin plug
Manufacturer Part Number 576680
Web Attribute Set Random Orbit Sanders
EAN Barcode 4014549371992
