Festool
Festool ROTEX RO 150 FEQ-Plus Sander
SKU: 571592
£659.98
£549.98 Excl. VAT
  • Extended abrasive life with MULTI-JETSTREAM 2 pad, reduces heat and prevents clogging
  • Eccentric motion for high quality, scratch-free surfaces
  • Perfect grip position for every working situation
  • Pad made from MPE high tear resistant durable material
  • Minimal vibration
  • FastFix tool free sanding pad system, Plug It Hose
  • Sanding up to the edge, bottom of handle can be removed
  • 3 Year warranty on registration (excluding base) available
This RO150FEQ Rotex sander from Festool is more powerful, economical and ergonomic and few other sanders offer such control and high finish. Rotex was the very first geared eccentric sander and set ground-breaking standards with its innovative 3-in-1 principle. Coarse sanding, fine sanding or polishing, it does the work of three tools. The powerful motor and long life gear unit gives high performance under load, fitted with an MPE MULTI-JETSTREAM 2 sanding backing pad.
The MULTI-JETSTREAM 2 pad works using intake air and exhaust air to generate airflow transporting the sanding dust away from the pads surface so that the abrasive wears evenly without clogging as well as keeping the surface at a low temperature. The result is almost 100% dust extraction for an improved rate of material removal, a better finish and a healthy working environment. Made from MPE high tear resistant material the pad is also very durable.
Supplied with MPE sanding base (soft), edge protector and Systainer T-LOC SYS3 storage case.
Dust Extraction 27 mm Outlet
No Load Speed Rotary 320 - 660 rpm, Orbital 3,300 - 6,800 opm
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 93 dB(A) [3.0 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 82 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] 4.0 m/s² [1.5 m/s²]
Motor Power 720 W
Manufacturer Part Number 571808 & 571809
Voltage 230 V
Web Attribute Set Dual Action Sanders
EAN Barcode 4014549149034
