Festool
Festool RTS 400 REQ-PLUS Palm Sander
SKU: 103072
£429.98
£358.32 Excl. VAT
  • Small, compact and only 1.2kg
  • Ideal for use when working overhead or on vertical surfaces
  • High speed with small 2.0mm orbit
  • Virtually vibration free, clean and efficient
  • StickFix hook and loop base, economical use of abrasive
  • Clip-on light module for improved visibility
  • Plug-It removable mains cable system
  • Supplied with dust bag and has a 27mm dust extraction outlet
  • Pad size 80 x 130mm
Relatively light in weight, this sander is comfortable and controllable for single-handed use. It is easy to use even for extended periods of time, efficient and clean. This rectangular pad, orbital sander is ideal for sanding in small spaces, sanding small surfaces and for final finish sanding. It is as quiet as a finishing sander can be, operates smoothly, weighs just 1.2kg and is perfectly balanced. The high speed and small orbit diameter just 2.0mm leaves an excellent finish. The electronic speed control ensures the sander maintains its speed under load and transfers all 250W of power directly to the work surface. It features Festool’s reliable CLEANTEC extraction connecting system. Connecting it to a vacuum results in virtually zero sanding dust left on the surface you are sanding or in the air. Alternatively, you can use the durable, reusable long-life chip collection bag supplied with the machine. The clip-on light module illuminates your sanding area and makes it easier to recognise unevenness. Thanks to vibration detection, the light module switches on and off automatically, and can be set to full or dimmed light. The RTS 400 REQ-Plus comes in a Systainer case along with a PROTECTOR, for smooth sanding along window surfaces, frames and panelling, plus a long-life dust bag. Another Festool product well worth the investment. Pad size 80 x 130mm. Please note: the purchase of an additional pad saver will prolong the life of the sanding pad.
Dust Extraction 27 mm Outlet
No Load Speed 6,000 - 12,000 rpm
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 84 dB(A) [3.0 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 73 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] 2.5 m/s² [1.5 m/s²]
Motor Power 250 W
Plug Fitted UK 3 pin plug
Manufacturer Part Number 201220
Web Attribute Set Palm Sanders
EAN Barcode 4014549255223
