This multi-functional work table can be turned into a very versatile work surface and folded away after if space is at a premium. The MDF top is perforated over its entire surface with 20mm holes to take a range of accessory clamps, rails and stops to hold, cut and machine work accurately. Due to the amount of position available for clamps and stop it can be easily be adapted to take regular and irregular shaped workpieces up to 78mm thick and 700mm wide. Overall table size 1,157 x 773mm, Table height 900mm (with legs folded 180mm), Load capacity 120kg and weight 28kg. Supplied as basic version without accessory clamps and rails.
Table Height 900 mm (180 mm with legs folded)
Table Size 1,157 mm x 773 mm
Manufacturer Part Number 500608
Web Attribute Set Festool CMS Moduler System and MFT Table
EAN Barcode 4014549229927
