A really great tool to use, almost impossible to clog as waste falls straight through the lattice. It is actually made up of strips of double edge saw blade material, welded and pinned to form a rigid blade 25mm wide by 230mm long, coarse on one side and fine on the other. Unusually for a Japanese tool it cuts on the push stroke. Blade length 230mm. Fitted with a non-slip comfort grip handle.
Grade Coarse & Fine
Rasp Type Saw Rasp
Web Attribute Set Hand Rasps Rasp Length: 230 mm
EAN Barcode 4986744610032
