Designed for large workshops where air quality and efficiency is key, the Axminster Professional SD2080CE Cyclone Dust Collector delivers excellent performance with a range of smart features.
Cyclone dust extractors efficiently separate larger waste from fine dust before it reaches the fan, allowing the fan to maintain constant speed and suction performance. Heavier waste collects in one container, while finer particles gather in another, helping to reduce the filter load. The cyclone separation system feeds into a generous 175 litre collection drum, which features a quick release mechanism and a clear display window so you can monitor fill levels at a glance.
The powerful 2.2kW motor drives the lightweight impeller, delivering an impressive airflow of 2,080 m3/hr at 152mm. The impeller reduces noise and energy consumption, while maintaining high static pressure (3,027 pa) for effective extraction across multiple machines.
The manual double paddle filter cleaning system keeps the 8m² filter surface operating a peak efficiency, extending filter life and maintaining airflow so minimal downtime is required. The advanced filtration performance captures 99% of particles down to 1 micron, ensuring cleaner air and healthier working environment.
Connecting multiple machines is easy thanks to the variation of inlet sizes; choose the 200mm inlet, or split down into 3 x 100mm inlets.
Castors feature on the base, allowing easy positioning and manoeuvrability in the workshop.
The Bluetooth RF remote control enables wireless operation, so you can effortlessly switch on/off from anywhere in the workshop.
Supplied with a 16A plug, running on 230V.
Please note, if you require an EU plug, please ensure you purchase 113776
Airflow 2,080 m³/hr @ 152 mm
Filter Performance 99% 1 micron
Inlet 1 x 200 mm or 3 x 100 mm
Overall L x W x H 1,270 x 753 x 1,990 mm
Power 2.2 kW
Rating Frequent Use
Sound Power Level LwA [Uncertainty K] 85 dB(A)
Plug Fitted UK 16A Plug
Model SD2080CE
Bag Capacity 85 litre
Container Volume 175 litre
Filter Surface Area 8 m²
Nett Weight 122 kg
Static Pressure 3,027 Pa
Voltage 230 V
EAN Barcode 5052511142477
  • UK Mainland - £70
