The Laguna C|Flux 1 Cyclone Dust Extractor is a superior solution for maintaining a clean and efficient workspace. It effectively separates heavy waste material from fine dust before the airflow reaches the fan, enabling the fan to operate more efficiently at a consistent speed. This advanced dust extractor is designed with the user in mind, offering a range of features that ensure superior performance and convenience. This high-efficiency particulate air filter with a high filtration level of 99.7% at 1 micron particle size that ensures fine dust particles are captured, providing a healthier working environment.
One of the standout features of this extractor is the 1 micron pleated filter, which comes complete with a cleaning paddle. The cleaning paddle makes maintenance a breeze, so you can keep your extractor running at peak performance. The remote control feature adds an extra layer of convenience, allowing you to operate the machine effortlessly from a distance.
The twin outlet design, featuring two 100mm outlets and an optional single 150mm outlet, provides versatility and allows you to hook up the extractor to a large machine with ease. The chute is designed to maximise airflow, with the fan housed inside a single horizontal plenum, reducing airflow resistance.
The larger waste is collected in a drum that has an innovative lift system allows for easy attachment or detachment with a simple lever. The drum, which is octagonal in shape, is raised off the ground and securely seals against the lid. When elevated, the CFLUX1 can be effortlessly moved on its four sturdy castors attached to the frame. Once lowered, the drum rests on another set of wheels, making it easy to roll to the desired emptying spot.
With the Laguna C|Flux 1 Cyclone Dust Extractor, you get a powerful, efficient, and user-friendly solution that enhances your workspace and promotes a healthier working environment. Experience the difference with Laguna – the ultimate solution where quality seamlessly meets innovation.
Axminster Tools offers an optional 2-year extended warranty on all Laguna machines, ensuring peace of mind and comprehensive coverage. This extended warranty must be purchased at the same time as your Laguna machine. Please see the warranty link below for more details.
Supplied with remote start handset, 1 collection bag for main drum, 1 collection bag for filter dust.
Airflow 1,786 m³/hour (1,051 cfm) Traditional, 1,224m³/hour (720 cfm) Realistic
Filter Performance 1 micron
Overall L x W x H 1,092 x 610 x 1,753 mm
Power 1.1 kW
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 82 dB(A)
Plug Fitted UK 16A Plug
Model C|Flux 1
Bag Capacity 113 litre
Hose Diameter 1 x 150 mm or 2 x 100 mm
Nett Weight 105 kg
Voltage 230 V
Warranty Laguna 1 Year Warranty, Axminster Tools Extended 2 Year Available
EAN Barcode 5052511135424
  • UK Mainland - £70
