The Laguna P|Flux 3 Cyclone Extractor HEPA is a cutting-edge solution designed to revolutionise your workspace. This advanced extractor combines powerful cyclone technology with with two-stage separation of chips, shavings and dust particles, ensuring a cleaner, healthier environment. Designed for efficiency, convenience, and performance, this extractor is the perfect addition to any serious workshop. Invest in solutions that elevate your workspace with Laguna.
One of the standout features of the Laguna P|Flux 3 is its cyclone technology. This powerful cyclone system effectively separates fine dust from larger waste chippings, preventing clogging and maintaining consistent suction power. The result is a cleaner workspace and improved efficiency in your dust collection process. This system not only improves the performance of the extractor but also extends the life of the filters.
The upkeep is effortless with the fully automated paddle cleaning system. During operation, cleaning automatically begins every 10 minutes and every time the cyclone is stopped. This maintenance-free feature ensures your filters remain clean and operate at peak performance, reducing downtime and ensuring consistent performance. The 0.4 micron pleated filter ensures that even the finest dust particles are captured. The filter is easy to clean and maintain, providing long-lasting performance. A further enhancement is the riveted steel fan with a backward curved fin design. This robust fan delivers powerful suction while maintaining energy efficiency, ensuring that your extractor operates at its best.
The high-efficiency particulate air (HEPA) filter is another key component of this extractor as it allows even the smallest dust particles, down to 0.4 micron, to be captured. Previously, HEPA material was too delicate to incorporate an internal paddle cleaning system. However, a recent innovation has introduced a Teflon membrane on the inner wall of the HEPA material. This membrane improves the inner surface of the filter, enabling dust to move down more smoothly and quickly, reducing dust build up on the wall. As a result, the filter's efficiency and lifespan are extended, and it becomes durable enough to accommodate the cleaning system.
Noise levels are kept to a minimum thanks to the swing-away doors with acoustic foam liner. This design feature reduces the noise generated by the extractor, creating a quieter and more pleasant working environment at just 76dB. Compared to a traditional extractor of equal size, which is around 86db, this gives a perceived volume level reduction of around 50% to the human ear.
Convenience is at the forefront of the P|Flux 3's design, with a remote control that allows you to start and stop the extractor from a distance. Operator signals, including a warning light and audible alarm, alert you when the collection drum is full. This feature ensures that you never have to guess when it's time to empty the drum, preventing overflows and maintaining optimal performance. The LED drum illumination provides clear visibility inside the collection drum, making it easy to monitor the dust levels and ensure timely emptying. The semi-automatic emptying system allows for no-mess disposal of fine dust collected in the canister drum, keeping your workspace clean and tidy.
Ease of use is another key consideration of the Laguna P|Flux 3. The collection drum instantly detaches for quick and easy emptying, while the simple connection hose inlet with splitter and rubber blanking caps makes setup effortless. Portability is another advantage of this extractor, with four swivel castors that allow you to easily move it around your workspace. This feature ensures that you can position the extractor exactly where you need it, providing maximum flexibility and convenience.
This machine is available in 230V or 415V. Please ensure that your workshop electricity supply is adequate for these machines. If unsure, seek advice from a qualified electrician.
N.B. 230V machine requires a 32amp supply and it's recommended that a C Type breaker is used. 415V machine requires a 32A supply, (5 pin, 3 x L, N + E for 415V supply).
Axminster Tools offers an optional 2-year extended warranty on all Laguna machines, ensuring peace of mind and comprehensive coverage. This extended warranty must be purchased at the same time as your Laguna machine. Please see the warranty link below for more details.
Airflow HEPA 3,831 m³/hour (2,253 cfm) Traditional, 2,209m³/hour (1,300 cfm) Realistic on 200mm main duct
Filter Performance 0.4 micron
Overall L x W x H 1,219 x 711 x 2,209 mm
Power 2.2 kW
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 76 dB(A)
Cable Length 1.8 m
Model P/Flux HEPA
Bag Capacity 175 litre
Hose Diameter 1 x 200 mm or 3 x 100 mm
Nett Weight 169 kg
Warranty Laguna 1 Year Warranty, Axminster Tools Extended 2 Year Available
Voltage 230 V
EAN Barcode 5052511135448
  • UK Mainland - £70
