The Fiskars X28 Splitting Axe & Sharpener Set is designed for splitting medium-sized logs from 20-30cm in diameter. Featuring a wider splitting wedge and precision-ground forged steel blade, it delivers powerful, efficient splitting performance while helping the blade release cleanly from the wood.
The ultralight FiberComp™ handle is virtually unbreakable and perfectly balanced for increased striking power and control. A low-friction blade coating reduces resistance and helps protect against rust, while the oversized SoftGrip™ handle provides a secure, comfortable grip. The included Xsharp™ sharpener makes it easy to maintain a keen edge on both axes and knives.
Designed in Finland, Fiskars tools are renowned for combining innovative design, durability and performance. The X28 axe is backed by a 25-year warranty.
Supplied with; 1 x Fiskars X28 Splitting Axe, 710mm (28), 1 x Protective Sheath, 1 x Fiskars Xsharp™ Axe & Knife Sharpener
Overall Length 710mm (28)
EAN Barcode 6411501706669
