The Fiskars X36 is engineered to deliver exceptional splitting performance on large logs where maximum power, stability and efficiency are essential. Its extra‑wide blade and integrated splitting wedge drive deep into dense timber, helping the axe power through logs over 30 cm in diameter while making removal smooth and effortless.
The advanced blade‑grinding geometry creates a razor‑sharp edge for cleaner, more effective splits, and the double‑hardened, forged steel construction ensures the blade holds its sharpness for longer. A low‑friction coating minimises resistance with every strike and provides additional protection against rust.
Designed for both safety and long‑term durability, the X36 features a permanently attached head‑to‑shaft connection for complete confidence during heavy‑duty use. The ultralight FiberComp™ shaft is virtually unbreakable and offers outstanding overstrike protection, while its perfectly balanced weight distribution maximises the impact energy delivered with each swing. An oversized SoftGrip™ handle with strategic texturing provides comfort, grip and control, and the hooked end ensures a secure hold throughout the strike.
With over 375 years of design heritage, Fiskars is recognised globally for crafting tools that combine performance, precision and ergonomic excellence. Manufactured in Billnäs, Finland, the X36 reflects the brand’s commitment to durable, high‑performance tools trusted by professionals, woodworkers and homeowners alike.
The Fiskars X36 Splitting Axe is ideal for large‑scale log‑splitting tasks, particularly hardwoods and oversized rounds that require high-impact power and control.
Looking for a different size or splitting power? Explore the full Fiskars axe range for smaller, larger, and extra‑powerful options.
A protective sheath is included for safe storage, and the axe is backed by Fiskars’ 25‑year warranty.
Length: 915 mm (36)
Overall Length 915 mm (36)
EAN Barcode 6411501201683
