Shokunin
Shokunin Japanese Flushcut Saw - 100mm
SKU: 108538
£8.98
£7.48 Excl. VAT
  • Cut and flush trim dowels, plugs, through tenons
  • Single edged; 25 tpi, no set, scratch-free
  • Japanese toothing, rapid cut with clean finish
  • Highly flexible blade tapers for better access
  • Overall length 210mm, with 100mm blade
  • Made in Japan
Destined to bring a smile to your face everytime you use it. The Shokunin Flush Cut saw trims dowels, through tenons or plugs flush, without damage or scratching the surrounding surface. The 25tpi Japanese toothing cuts on the pull stroke. The 100mm long blade is 0.3mm thick and highly flexible. It can be pressed flush to any surface. The teeth have no set, and yet cut rapidly leaving a very clean finish. The blade tapers in length for easier access in tight spots. Overall length 210mm, fitted with a comfortable beech wood handle. Made in Japan.
Blade Thickness 0.30 mm
Web Attribute Set Japanese Specialist Saws
EAN Barcode 4903524011506
