Shokunin
Shokunin Japanese Flushcut Saw - 125mm
SKU: 105019
£11.58
£9.65 Excl. VAT
  • Perfect for cutting the protruding dowels or tenons
  • Double-edged blade, zero set will not mar the surrounding surface
  • Made for both hardwoods and softwoods
A small saw, traditionally used in Japanese joinery for flush trimming protruding wooden or bamboo nails, used to pin joints. The thin blade is incredibly flexible. Even after bending beyond 90 it springs back true. The crosscut teeth of this saw have zero set. It can cut a dowel or tenon flush without marring the surrounding surface.
When using this saw, it helps if you gently rest the fingers of your free hand on the back of the blade just behind the cut. This gives much greater control. The blade has two edges, a fine tooth pitch on one side for hardwoods and a slightly coarser pitch on the other for softwood. The blade length is 125mm fitted with a beechwood handle, overall length 270mm.
Blade Thickness 0.30 mm
Additional Accessories Yes
Web Attribute Set Japanese Handsaws
EAN Barcode 5052511101924
