HVLP turbines supply air at a much lower velocity producing a softer, easier-to-control spray. This allows you to lay the paint on gently and not blast it on. The benefits of HVLP include less overspray and less paint wastage. Transfer efficiency can be as high as 85%. The quality of finish is identical to the best high pressure spray finishes. The Q5 Platinum Turbine with its powerful 5-stage motor produces approximately 9.5psi. This extra powe
EAN Barcode 5052511079278
