The Fuji Spray VALOR H100 is a professional‑grade compressor HVLP spray gun developed specifically for clear finishing, delivering outstanding atomisation, surface clarity and control for furniture making, cabinetry and fine joinery.
The VALOR H100 spray gun is supplied ready for workshop use with a durable nylon cup. Designed for compressor‑driven HVLP systems, it provides reliable, repeatable performance for professional finishing environments where consistency and finish quality are essential.
Engineered for demanding woodworking applications, the VALOR H100 features a forged aluminium gun body combined with anodised internal components, providing long‑term durability without unnecessary weight. Weighing just 435 g (without the cup), its lightweight, well‑balanced construction reduces fatigue during extended finishing sessions, making it ideal for large furniture pieces, built‑ins and production work.
Precision spray control is achieved through a side‑mounted fan adjustment with clear, easy‑to‑read markings, allowing accurate tuning for narrow components or wide flat panels. The spray gun is optimised specifically for clear coats, producing smooth, even atomisation that enhances grain clarity and surface depth across hardwoods, veneers and fine furniture.
The VALOR H100 is fully compatible with modern woodworking finishes, including both waterborne and solvent‑based clear coats such as lacquers, varnishes, polyurethanes and shellac. Its simplified internal design reduces cleaning time between finishing sessions, helping maintain productivity in busy workshops.
Fuji Spray is a globally respected manufacturer of professional spray finishing equipment, trusted by woodworkers and finishers worldwide. The VALOR range represents Fuji’s most advanced spray gun technology, combining refined ergonomics, precise control and compatibility with modern coating systems to meet the demands of today’s professional workshops.
The VALOR H100 can be paired with 3M PPS cup systems for faster colour changes and easier cleaning, or used alongside other Fuji VALOR spray guns to create a dedicated basecoat and clear‑coat finishing workflow.
Supplied with a 600cc nylon cup and a 1.4 mm air cap fitted as standard, the gun can also be used with 3M PPS and other major cup systems when fitted with the appropriate adapter, offering flexibility for colour changes and simplified material handling. Alternative 1.3 mm (SKU 114341) and 1.7 mm (SKU 114343) air caps are available separately, making this ideal if a different size is required or as a direct replacement.
