Fuji
Fuji Spray VALOR MINI H50 Spray Gun
SKU: 114126
£339.98
£283.32 Excl. VAT
  • Compact HVLP design ideal for spot repair and tight areas
  • Lightweight, ergonomic body for reduced fatigue
  • Precise side‑mounted fan control for accurate spray patterns
  • Suitable for waterborne and solvent‑based coatings
  • Compatible with 3M PPS and other major cup systems
  • Low 4.9 CFM air consumption for efficient refinishing
The Fuji Spray VALOR Mini H50 is a compact, high‑precision HVLP spray gun designed for detailed work and spot repair, delivering controlled, professional results in confined and intricate areas. Designed for compressor‑driven HVLP systems, it offers excellent control and manoeuvrability straight out of the box, with compatibility for 3M PPS and other major cup systems when fitted with the appropriate adapter.
Engineered for precision refinishing, the VALOR Mini H50 features a compact, lightweight body that allows accurate material placement in tight contours and hard‑to‑reach spaces. Its well‑balanced design and finely adjustable fan pattern provide consistent spray control while maintaining the professional finish quality expected from the VALOR range.
With an air consumption of just 4.9 CFM and an efficient operating pressure range of 9–25 PSI, the Mini H50 performs exceptionally well with smaller compressors, making it ideal for workshops with limited air supply. Despite its compact size, it delivers reliable, repeatable atomisation suitable for both basecoat and clearcoat applications.
The spray gun supports air cap sizes of 0.8 mm, 1.0 mm and 1.2 mm, allowing users to tailor performance to material type and application. It weighs just 337g (without the cup), helping to reduce fatigue during extended use, and offers a maximum fan width of up to 260 mm for added versatility. Fully compatible with waterborne and solvent‑based coatings, it is suited to a wide range of modern paint and finishing systems.
Fuji Spray is a globally respected manufacturer of professional spray finishing equipment, trusted by woodworkers, technicians and refinishing specialists worldwide. The VALOR range represents Fuji’s most advanced spray gun technology, combining precision control, refined ergonomics and compatibility with modern coating materials.
The VALOR Mini H50 is ideal for use alongside the Fuji VALOR H100 and VALOR M100 spray guns, creating a complete VALOR refinishing system that covers everything from basecoat and clearcoat application through to detailed spot repairs.
Supplied ready for use with a 200cc nylon cup and a 1.0 mm air cap and needle set.
Inlet 1/4 NPT
Web Attribute Set Spray Guns
EAN Barcode 5052511146734
