A small handy bowsaw for all-round use. The pointed nose makes the saw well suited for use in tight spaces and is ideal for pruning and roofing work. Size 530mm (21 in). Supplied with 2 blades: 1 standard dry cut and 1 wet wood cutting blade.
Bahco
Bahco 530mm Bowsaw with Dry and Wet Wood Cutting Blades
| Web Attribute Set | Bowsaws |
| EAN Barcode | 7311518286668 |
