TheThe Fiskars PowerGear™ Tree Pruner is engineered to give gardeners powerful, precise cutting performance when working at height or in dense growth. Designed for cutting fresh wood up to 32 mm in diameter, it extends your natural reach and allows you to trim branches safely from the ground without needing a ladder. The 230° adjustable cutting head makes it easy to approach branches from any angle, ensuring clean, controlled cuts even in awkward or overhead positions. Its lightweight design helps maintain accuracy while reducing strain during extended pruning sessions.
Built with comfort and reliability in mind, the PowerGear™ mechanism boosts cutting force where it’s needed most, helping you slice through thicker branches with minimal effort. Durable SoftGrip™ handles provide secure, comfortable control, while the non‑slip base and bright orange cutting support enhance visibility among foliage. Whether trimming tree crowns, shaping shrubs or clearing congested garden growth, this pruner makes it easier to work efficiently at height and at ground level without bending or kneeling.
With more than 375 years of cutting expertise, Fiskars is globally recognised for designing tools that combine high performance, ergonomic innovation and long‑lasting durability. The PowerGear™ range reflects this heritage, offering tools that deliver exceptional cutting power with reduced strain, trusted by gardeners of all experience levels.
The Fiskars PowerGear™ Tree Pruner is ideal for maintaining tree canopies, shaping tall shrubs, clearing dense growth, and performing overhead pruning safely and comfortably. Its lightweight, extended‑reach design makes it an essential tool for accurate, efficient cutting throughout the garden.
Need extra height for overhead pruning? See SKU112261 for a telescopic model with up to 6m reach.
Specification
Cutting Capacity: 32 mm
Length: 1,650 mm
Reach: Fixed length
Weight: 1,100 g
Intended Use: Medium reach pruning (head height, shrubs, small trees)
Web Attribute Set Pruning
EAN Barcode 6411501150134
