TheThe Fiskars X32 Splitting Axe is designed to deliver clean, precise and reliable performance for limbing, chopping, kindling preparation and general yard maintenance. Its thin, wide blade edge is optimised for fresh, resinous woods such as spruce and pine, allowing it to bite deeply and cut smoothly with minimal resistance. Thanks to advanced blade‑grinding technology, the cutting edge stays sharper for longer, ensuring cleaner, more controlled cuts with every strike. The double‑hardened, forged steel blade offers long‑lasting durability, while the low‑friction coating helps the blade glide through wood and protects it against rust.
Engineered for long‑term safety and durability, the X32 features a secure, undetachable head‑to‑shaft connection that withstands heavy use without loosening. The ultralight FiberComp™ shaft is virtually unbreakable and provides outstanding overstrike protection, helping to reduce shock and keep the tool safe and reliable during demanding tasks. Perfect balance between the head and shaft maximises power and efficiency, while the ergonomically curved handle supports a natural wrist position for improved comfort. The SoftGrip™ texture ensures a confident, non‑slip hold throughout use.
With more than 375 years of world‑class toolmaking heritage, Fiskars is internationally recognised for producing high‑performance cutting tools that combine precision, innovation and ergonomic design. Created in Billnäs, Finland, the X32 reflects this long tradition of craftsmanship and engineering excellence.
The Fiskars X32 Splitting Axe is ideal for limbing trees, chopping small and medium logs, splitting kindling, general yard maintenance and even carpentry tasks that require a clean, accurate chopping action.
Looking for a different size or splitting power? Explore the full Fiskars axe range for smaller, larger, and extra‑powerful options.
A protective sheath is included for blade safety and easy storage, and the axe is backed by a 25‑year warranty.
Length: 355 mm (14)
Web Attribute Set Axes & Adzes
EAN Barcode 6411501201676
