The Hozelock 2515 Dial Sprinkler has a choice of 8 spray patterns to suit all watering shapes and types - small semi circle, large semi circle, mist, strip, large circle, small circle, square and remote jet. The sprinkler comes complete with soft-touch, easy-grip adjuster ring for changing spray patterns even with wet hands. It is mounted on a sled style base to suit all surfaces. Max. Area Coverage: 79m² (Max. Diameter 10m). Ideal for small gardens.
Hozelock
Hozelock 2515 Multi Sprinkler 79m²
| Web Attribute Set | Hose Pipe Accessories |
| EAN Barcode | 5010646045537 |
