The Hozelock 4-in-1 Multi Use Portashower is a compact, portable shower, which is only 460mm high and easy to store. It is ideal for camping and caravanning. The Portashower comprises of a pressure sprayer with air safety valve, an easy to control hand spray and 2 metres of hose. Approximate spraying time: 3 minutes. Capacity: 7 litres (5 Litre Max)
Hozelock
Hozelock 4140 4-in-1 Multi Use Portashower
| Web Attribute Set | Hose Pipe Accessories |
| EAN Barcode | 5010646051361 |
