This Roughneck® Round Shovel has a sharp serrated edge, ideal for digging in compacted ground, slicing through roots and opening bulk bags or bags of cement. The long fibreglass handle is fitted with a contoured grip, it offers increased leverage and power, allowing for a more comfortable, upright position to be maintained whilst digging. Perfect for deeper holes and trenches. Built to last, it is manufactured from heavy-duty, carbon steel with a corrosion-resistant, tumble lacquered finish. Treads on the blade allow for increased pressure to be applied with reduced risk of slippage. The Power Ring socket, steel-reinforced plug, provides a stronger blade to handle connection.
Specification: Blade Width: 225mm
Overall Length: 1460mm (57.1/2)
Web Attribute Set Builder's Shovels
EAN Barcode 5057902680446
