A great addition to any home workshop, large or small
The Axminster Workshop AW1950B Bandsaw is a premium, compact bandsaw with many new features not normally found on machines of this size.
Buy with confidence
A red and silver band saw machine with open side doors, shown against a brown wood plank wall background.
Smooth running
A steel body and balanced aluminium wheels ensures the machine runs very smoothly.
Motor housing and dust extraction on a 1950 Axminster workshop bandsaw
Excellent dust extraction
With dual extraction ports, you can rest assured you’re safeguarding not only your health, but keeping your workshop clean at the same time.
Upper and lower bearing guide supports shown on an Axminster Workshop bandsaw
The ball bearing blade guides make the bandsaw easier to set up and also help to achieve more accuracy when cutting.
Twin trunnions supporting the table on an Axminster Workshop bandsaw
Twin trunnion table support
This provides excellent support and aids towards a vibration free cut.
A close-up of a person using bandsaw to cut a vertical piece of wood, with their hands guiding the wood against the saw blade in a workshop setting.
Solid fence
A cam locking fence allows for accurate cuts. For convenience, it can be used either side of the blade.
Person sets a mitre fence on an Axminster Workshop bandsaw
Optional mitre fence available
A standard 19mm mitre fence slot provides the option for many optional accessories to be used.
A close-up of a bandsaw cutting a sheet of material over a wooden surface, with the AXCALIBER brand name and a British Made badge visible on the image.
Choose your blade
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
The AW1950B is a compact bandsaw with many features not normally found on machines of this size.
It gives you a 135mm maximum depth of cut. It has a strong welded and braced steel frame along with a generously sized cast iron table with a steel plate rear extension. The widely spaced mounting trunnions underneath the table give extra table support and ensure that the table tilt is a smooth operation. A standard 19mm mitre fence slot is provided. The rip fence cam-locks solidly to the front rail and is adjustable to the blade for accuracy. Twin scales allow the fence to be used on either side of the blade.
The bandsaw has ball bearing side and thrust guides; these give great support and are very easy to set up. Once set, they stay set unless you change the width of the blade. A rack and pinion system adjusts the upper blade guide height.
The dust extraction is via two ports, one close to the bottom guides, the other in the lower wheel cabinet. An interconnecting hose means just one 63mm connection port needs coupling to a suitable vacuum extractor. There are twin blade speeds, giving flexibility for many jobs. A powerful induction motor with a multi V belt drives the bandsaw and is quiet and reliable.
Supplied with a steel leg stand with rubber feet and a UK made blade (10mm x 6 TPI Skip Tooth). This could be the perfect bandsaw for most shed-in-the-garden-garage-workshops.
Please note, if you require an EU plug, please ensure you purchase 113504
Dust Extraction Outlet 63 mm
Max Width of Cut with Fence 185 mm
Overall L x W x H 790 mm x 620 mm x 1,570 mm
Power 550 W
Rating Regular Use
T Slot Size 19 mm x 9.5 mm (3/4" x 3/8")
Table Height 1,035mm
Table Size 350 x 330 mm
Table Tilt 0 - 45
Min Extraction Airflow Required 390 m³/hr
Sound Power Level LwA [Uncertainty K] 90 dB(A) [1.5 dB]
Sound Pressure Level LpA [Uncertainty K] 82.2 dB(A) [1.5 dB]
Plug Fitted UK 3 pin plug
Web Attribute Set Bandsaws
EAN Barcode 5052511124541
Accessories
  • UJK Bandsaw Buddy UJK Bandsaw Buddy
    £16.49 £19.98 Save £3.49
  • Axminster Mitre Fence For 19mm Slots Axminster Mitre Fence For 19mm Slots
  • Axminster Dual Axis Featherboards (Pair) Axminster Dual Axis Featherboards (Pair)
  • UJK Level Box UJK Level Box
    £21.11 £25.58 Save £4.47
