The Scan Impact Cut Resistant Work Gloves provide a high level of hand protection without compromising comfort or dexterity. Featuring a Cut D-rated liner and flexible impact protection panels, they are ideal for handling materials, using hand tools and working around sharp edges.
The sandy foam nitrile palm offers excellent grip in both wet and dry conditions and resists oil and grease, while a reinforced patch between the thumb and forefinger improves durability in high-wear areas. Touchscreen compatibility allows you to use electronic devices without removing the gloves.
Scan Safety produces dependable PPE and workwear designed to help keep professionals safe and comfortable in demanding working environments.
Supplied With:
1 x Pair of Scan Impact Cut Resistant Work Gloves, Size 9 (Large)
1 x Belt Clip
Web Attribute Set Gloves
EAN Barcode 5023969017617
