Axminster Aluminium Oxide Grinding Wheel 200mm x 40mm
SKU: 106549
€23,00
  • Ideal for sharpening tool steel, fast cutting 80g aluminium oxide
  • Softer bond, less chance of overheating the tool
  • 40mm wide, 200mm diameter, 15.88mm (5/8) bore
White aluminium oxide grinding wheels have a slightly softer bond compared to standard grey grinding wheels. They are the ideal choice for sharpening tools as opposed to grinding. White wheels cut freely with far less tendency to overheat and draw the temper of the steel. This stone is 40mm wide, 80 grit for fast results and 200mm diameter with a 15.88mm (5/8) bore.
Web Attribute Set Replacement Grinding Wheels
EAN Barcode 5052511119493
