A replacement 40mm wide 80 grit aluminium oxide wheel for use with the Axminster AWBGDL and AC150WSG wide stone grinders. 150mm diameter and a 12.7mm bore, insert included to fit 12.7mm (1/2") shaft. (31.75mm without the insert)
Axminster Workshop
Axminster Wide Wheel for AWBGDL/AC150WSG Bench Grinder
| Web Attribute Set | Replacement Grinding Wheels |
| EAN Barcode | 5052511072330 |
