Tormek
Tormek SG-250 Original Grindstone - 250mm
SKU: 910079
€190,00
  • Smooth surface finish
  • Cuts all types of tools & steel qualities including HSS
  • 250mm diameter wheel, 220 grit
The Tormek Original Grindstone has evolved over the years to offer the best combination of efficient steel removal, smooth surface finish and a long life. This stone efficiently cuts all types of tools and steel qualities including HSS. 250mm diameter wheel, 220 grit. The wheel comes as standard with the Tormek T-8 Original. Fits Tormek T-8, Tormek T-7 and previous Tormek models with a 250 mm stone diameter.
Web Attribute Set Replacement Grinding Wheels
EAN Barcode 7392485001027
