MICROJIG
MICROJIG MATCHFIT Dovetail Rachet Clamp AP
SKU: 114581
€50,00
  • Fast-acting dovetail ratchet clamp with simple one-handed operation
  • Anti-Pivot Spring keeps the clamp arm in position between adjustments
  • Compatible with MATCHFIT dovetail tracks and standard 12mm x 8mm T-slots
  • Ratchet mechanism delivers secure, vibration-resistant clamping force
  • Quick-release button allows fast repositioning and workflow changes
  • Large padded clamping face protects delicate workpiece surfaces
  • Long handle provides excellent leverage and ease of use
  • Ideal for woodworking, routing, sanding, carving and jig building
The MICROJIG MATCHFIT Dovetail Ratchet Clamp AP is a fast and versatile dovetail ratchet clamp designed to provide secure workholding for woodworking, routing, sanding and assembly tasks. Featuring MICROJIG's innovative Anti-Pivot (AP) Spring technology, the clamp arm stays exactly where you position it, making repetitive clamping faster and more efficient. Compatible with MATCHFIT dovetail tracks and standard 12mm x 8mm T-slots, this quick clamp system delivers powerful, vibration-resistant clamping while protecting work surfaces with a large padded clamping face.
Web Attribute Set Guide Clamps
