A place for everything and everything in its place, sums up the Faithfull Fold Out Screwdriver and Bit Set. 63 pieces and everyone of them will come in handy, now that's what we call useful. This versatile set covers a range of applications around the home or workshop. The storage case features two hinged side wings, which open out so you can see at a glance whichever item you require. This impressive set contains seven soft grip screwdrivers, six precision screwdrivers, 36 1/4
Full contents list:
2 x Slotted Screwdrivers: 6 x 125mm and 3 x 75mm
3 x Phillips Screwdrivers: PH0 x 75mm, PH1 x 75mm and PH2 x 100mm
2 x Pozidriv Screwdrivers: PZ1 x 75mm and PZ2 x 100mm
6 x Precision Screwdrivers: Slotted 2.5 x 50mm, 3 x 50mm, PH00 x 50mm, PH000 x 50mm, TX8 x 50mm and TX9 x 50mm
2 x Offset: PH2 x 6mm and PH1 x 5mm
1 x Bit Driver
7 x 25mm Phillips Bits: PH0, PH1(x2), PH2(x2) and PH3(x2)
9 x 25mm Pozidriv Bits: PZ0, PZ1(x3), PZ2(x3) and PZ3(x2)
7 x 25mm Star Bits: TX10, TX15, TX20, TX25, TX27, TX30 and TX40
4 x 25mm Hex Bits: H3, H4, H5 and H6
4 x 25mm Hex Security Bits: S0, S1, S2 and S3
4 x 25mm Slotted 3, 4, 5 and 6mm
1 x 1/4in Socket Adaptor
9 x 1/4in Hex Sockets: 4, 5, 6, 7, 8, 9, 10, 12 and 13mm
1 x Magnetic Holder
1 x Magnetiser/Demagnetiser
