Replacement hardened tip for the Rider Bradawl. The tip fits into a 12mm hole in the handle and is held securely in place with a grub screw.
Bradawls are common tools used in many different trades. In woodworking these pointed tools are often used to scribe a line, along the grain when laying out and for making a starter hole for a screw. Over time they can become worn but, easily returned to as-good-as new condition with these replacement tips.
Made in Britain
Made in Britain Yes
Intended Use A small chisel tip used to produce a starter hole for a screw.
Web Attribute Set Bradawls & Gimlets
EAN Barcode 5052511132010
