This Stanley 5044 Bit Brace, 250mm/10in, has a 12-point, 3-way, ratchet for use in confined spaces. The head is ball bearing mounted for smooth operation and has a 13mm universal chuck with 4 jaws and with a holder for square tip bits.This brace is chromium plated for corrosion resistance and longer life, it has a reversible 8 tooth ratchet. Specification: Length 250mm.
Stanley
Stanley 5044 Bit Brace 250mm 10"
| Manufacturer Part Number | 1-02-715 |
| Web Attribute Set | Hand Drills |
| EAN Barcode | 3253561027154 |
