The Fiskars FSK137210 Premium Planters™ Transplanter works very well in hard ground and its narrow construction makes it perfect for use in narrow bed layouts and on balconies. The robust construction is complemented by a corrosion resistant stainless steel blade with a sharp blade edge for better penetration into the soil. The durable and lightweight FiberComp™ body makes it easy to handle and the hanging hole makes for easy storage after your planting work is done.
Specification
Length: 275mm
Width: 70mm
Weight: 0.11kg
Web Attribute Set Cultivation
EAN Barcode 6411501372109
