The Fiskars FSK137200 Premium Planters™ Trowel is the ideal tool for planting and transplanting in hard ground. Its robust construction makes it a perfect nursery tool with its corrosion resistant stainless steel blade. This trowel has a sharp blade edge for better penetration into even the most resistant soil. To better aid handling performance, the body is made from durable and lightweight FiberComp™. A hanging hole is incorporated in the handle for easy storage.
Specification
Length: 375mm
Width: 87mm
Weight: 0.13kg
Web Attribute Set Cultivation
EAN Barcode 6411501372000
