Plant bulbs and seedlings quickly and accurately with this precision tool. Its built-in measuring guide helps you dig to the ideal depth, while the circular motion design makes hole creation effortless. Once your bulb is in place, simply pull the release trigger to refill the hole with soil-no mess, no fuss.
Designed for bulbs up to 65mm wide with a planting depth of up to 125mm, it’s the perfect partner for gardeners who value both speed and precision.
Like every tool in the Fiskars Solid™ range, this planter is built to last. Its FiberComp™ construction delivers exceptional strength while remaining lightweight, weather-resistant, and easy to clean-so you can focus on your garden, not your gear.
Web Attribute Set Cultivation
EAN Barcode 6411501311344
