These FineLine tenon saws have a low friction PTFE coating on the blade. The coating makes cutting a very smooth operation even in man-made or treated timber. It just doesn’t seem like work anymore. The coating also helps protect against corrosion. Available in two sizes, blade has a cutting depth of 80mm. The electronically hardened, ultra-sharp teeth (11tpi) are precision diamond ground with three cutting edges. The saw cuts on both the push and pull stroke, giving fast efficient action and leaving a clean finish. The comfortable handle has a non-slip grip for extra sawing power. This saw is ideal for accurate cross and mitre cuts.
Axcaliber
Axcaliber Fineline PTFE Tenon Saws
| Length of Blade | 250 mm |
| Web Attribute Set | Tenon Saws |
| EAN Barcode | 5052511064854 |
