This fretsaw has a sprung steel frame which tensions the blade and a wooden handle. It will cut wood, metal or plastics with a suitable blade. The throat depth is 295 mm for deep access in sheet material. The blades are easy to change using plated wing screws with square nuts, ensuring the blade is securley clamped.
Axminster Fretsaw - 294mm Throat
| Web Attribute Set | Bowed Saws |
| EAN Barcode | 5052511046621 |
