This specially designed dozuki saw blade easily clips into the handle of our Small Dozuki Saw. It has sturdy teeth and a fine 21tpi pitch. These robust and sharp teeth are perfect for cutting intricate and precise joints in hardwoods. The special tooth grind enables cross, rip and mitre cuts with equal precision.
Blade Thickness 0.30 mm
Tooth Pitch \ tpi 1.21 mm \ 21 tpi
Length of Blade 150 mm
Saw Blade Type Crosscut
Web Attribute Set Japanese Back Saws
EAN Barcode 4963041071063
