Our panel carrier allows you to carry 2,400 x 1,200mm (8ft x 4ft) boards or sheet material safely. One hand takes the weight just like carrying a suitcase, leaving the other hand to steady the top of the panel. This carrier lets you move plasterboard singlehanded with very little effort. The carrier’s base is 335mm long. The channel has a 450mm long handle, with a 40mm offset to give clearance for your knuckles. The handle has a dipped PVC grip for a comfortable and secure hold. The all steel construction is powder coated for protection against corrosion.
Web Attribute Set Dry Lining Tools
EAN Barcode 5052511045174
